I have a 140hp evinrude and the 2 cylinders on the port side are heating up a lot faster than the 2 on the starboard. I have checked all hoses for leaks, replaced thermostat, relief valves, springs, gaskets......no change. Then I replaced the water deflectors under the heads.......no change. While i had the heads off I had the earmuffs on and both sides are getting equal water. I have not ran it so hot the heat alarm goes off, but by touch of hand, you can tell a huge difference. I'm running for about 3-5mins on earmuffs when testing.
So now I wonder, maybe port side is the correct temp, and sb side is running tooo cool????
