Re: head gasket
Is yours a U.S. Marine model? Just curious cause I own that same motor. Serial 3186. This motor is very easy to work on granted you can find the parts. HAve you had any troubles with it so far? Also if you are having compression problems in one or both cylinders check on the reeds. I just found mine to be gapped a little on the cylinder with low compression.
