Re: Head Gasket Torque and sequence
Selocs are good for cleaning up oil spills, especially when you are new to repairs. The factory manual cannot be beat.
You start in the center and spiral outwards and Joe stated. Imagine each of his numbers is a bolt and start in the center as he did. I would start with 10 or 12 ft/lbs to start, go through the pattern, then start again with the final torque setting.
