Head gasket replacement - re-torquing?
cp2smith
I recently replaced valves on my 4.3L V6. Everything is back together and its running perfectly. I torqued the head bolts to manufacturer's specs as per the Mercruiser service manual.
I've heard people recommend re-torquing the bolts after some running time. The service manual doesn't mention this, it recommends 3 stage tightening, which I did.
How important is it to re-torque them?
Colin Smith
boat127
Re: Head gasket replacement - re-torquing?
what you could do there is once you got your final torque is to let it sit for a couple hours and then re check the torque values after so you dont have to remove everything again like valve covers and exhaust manifolds
Ayuh,... I haven't Re-torgued a head since they came out with the composite gaskets We use today...
cp2smith
I've never re-torqued a head either. However it's a relatively simple task and I've had 3 or 4 people mention it's a good idea.
Thanks for the input.
