TwoBallScrewBall
- Sep 14, 2003
- 1,695
Two questions.<br /><br />1. What's the thinnest head gasket you can get? I noticed that when I changed out my head gasket on one bank I lost about 4-5 psi per cylinder. I bought a pair but only did one side so far. I just compared the old gasket to the spare new one, and noticed that the old gasket is a 0.070 and the new gasket is a 0.100 which probably accounts for the compression difference. <br /><br />2. Also comparing the old and new gaskets, I noticed that though the gaskets are the same manufacturer, the old gasket has "block side" stamped on the printed side. I looked for this on the new gasket but couldn't find it when installing. I now found it, and in teeny tiny letters the new gasket says "head side" on the printed side. How bad is it if the new gasket is installed upside down? It is....<br /><br />thanks<br /><br />Thanks!
