head gasket or exhaust sounds
DAMIFINO
I have a 1979 vip with a late model 2006 140 hp mercruiser 181 4cyl motor. I hit the throttle pretty hard when all of a sudden I developed a noise
that sounded like an exhaust leak, sort of a choo choo train like sound without the oo. (ch ch ch ) I pulled the exhaust today and noticed the head gasket looks in one spot to be protruding slightly out from under the head with a tear in it. something like a cork gasket might do if tightened down to much. engine runs, no water in oil, not overheating. my question is, will a head gasket make this sound and can I check this without putting the exhaust back on?
boatguya1
Re: head gasket or exhaust sounds
Pull the coil wire out and crank it over watching this gasket anomoly you've found if it's the problem you should see/hear it. I'm at the marina at Canyon Lake stop and see me sometime.
James
DAMIFINO
That confirmed it, the head gasket blew out from the compression and pushed the gasket out from between the head causing a split all the way to the cylinder.
Thanks for the info. at least now I know what has to be done
