I have a 77 Johnson 35HP. After running, I notice oily water running down the exhaust housing and when I remove the engine cover, there is oily water in the bottom of the case.
I've checked the carb to see if fuel was leaking from there, but it is ok. I just can't seem to locate the source of the leak. Since it has water and oil, I was wondering if it could be leaking out of the head. The gaskets have not been changed in a long time. Any thoughts? Thanks-Jeff.
