hds 7 gen 2 transducer
fisheymikey
hi everyone!
I just was going threw some tutorials in regards my unit and I never set the transducer type
I looked all over the place on the transducer and there is no indedification on the cable or the
transducer itself..
is there way to figure this out?
thanks
mike
ondarvr
Re: hds 7 gen 2 transducer
Is it the one that came with the unit, or did you buy a different one? The box normally says what transducer is included with the unit, if one came with it, you have the choice on these units to buy it with, or without one.
fisheymikey
that's the problem don't have the box anymore...
and yes it did come with the unit
thx
ondarvr
These were the two, without a marking identifying it I don't know how to tell. In the menu it should have an option on which frequency you want to use, the unit should be able to sense which transducer is connected and only give those two options.
Insight USA + 50/200 kHz transducer 000-10529-001
Insight USA + 83/200 kHz transducer 000-10530-001
fisheymikey
Hi everyone!
if ever this occues to someone else here is what you do.
call Lowrance with your serial of the Chartplotter and it will provide the tranducer that came with it.
so don't waste your time like I did wasting other ppl time and give lowrance a call. I never would have thought they would know which ducer was included
GA_Boater
Glad it worked for ya. I would have been surprised if they didn't know what they sell.
