Having trouble removing base of motor to access water pump
Mr. Papagiorgio
I'm trying to remove the bottom part of the motor to change the water pump and I'm having problems removing it. The motor is a yamaha 225 saltwater series fuel injected.I made sure to remove all bolts but I still can't get it off. The back end closest to the boat is where my problem is; Im able to loosen the front about 1/4 inch. Not sure the last time it was removed. I tried tapping with rubber mallet and wiggling the best I could. Any advice or tips on removing it? Thank you
Japie
Re: Having trouble removing base of motor to access water pump
Have you disconnected the gear shift rod that runs up the middle?
Mr. Papagiorgio
No I have not, where is that located and how is it removed?
Japie
Sorry been away from my pc for a bit, if you have not found it yet try following the linkages from the outside of the motor where the gear shift cable joins up, also get someone to help you, I think the leg will be fairly heavy.
ablock
Thier should be a bolt going from top of the motor in towards the bottom. Lift up your tilt and locate the anode it is round and should have a little triangle by this time it should be witish and all corroded it is thier to protect your motor from salt it is a metal that is used to corrode itselfe instead of letting your engine corrode. Thier should be a bolt holding it and it should be accesible through the top dirrectly on top of the anode it is also used to help correct steering pull
