have spark, fuel, and air
briber
have an 3.0l engine that ran great last year, and won't start this year. I have spark at plugs, fuel going to carb, and it wont fire up at and. everything turns over fine, just wont run. have tried jumping kill switch, checked neutral switch, and still wont run. any ideas of what to check next?????
bruceb58
If you pump your throttle do you see squirts of fuel going into the carb throat?
Points or electronic ignition?
briber
yes I can see fuel going into carb, and its fresh fuel this year as I drained the tank before winterizing
Bt Doctur
thats not what I asked .All you see is something squirting down the carb.take a tissue, pump the carb, wet the tissue ,see if it burns
If testing for spark with the coil lead close to ground the rotor may be broken
If testing with a plug wire then rotor is still good
Bt Doctur
from the time it ran good till now ,was any work done to the motor
Bt Doctur
says spark at the plugs, says the liquid from the carb is gas and burns then it should run. firing order is 1342 .
Compression test next to rule out stuck valves
