1992 Evinrude 60hp TE60TLENE<br /><br />I have installed a reman powerhead due to deeply scored #2 Cyl. I am not positive what caused the problem, a number of things may have contributed. Here is a list of what I have done so far:<br /><br />Replaced water pump asy with kit #432955 which includes revised thermostat spring.<br />Replaced thermostat.<br />Flushed coolant tube in mid section.<br />Replaced temp sensor per bulletin 2221.<br />Relocated tattle tale hose to top of block per bulletin SB2276r1.<br />Richened high speed jets per bulletin 2271<br />Cleaned all 3 Carbs & installed new needle & seats and gasket sets.<br />Replaced fuel filter.<br />Changed plugs from Autolite to Champion QL77JC4.<br /><br />I am planning to:<br />Clean oil reservoir, inspect all oil and fuel lines and connections.<br />Replace VRO pump (still on order).<br />Sync and link adjustments per manual.<br />Set idle timing to spec.<br />Change max timing from 19 degrees to 17 degrees per bulletin 2271.<br />Follow break in procedure as recommended by the rebuilder.<br /><br />Is there anything else I need to address?<br /><br />Thanks
