Re: Has anyone replaced their own rubrail>
I wrap boats for a living, and I can tell u that removing and replacing a rubrail is fairly easy to do urself, but with the proper tools it is even easier.
First, ru replacing just the rubber insert, or both the insert and the rail that screws into the boat? If it's just the rubber insert, then it should have two screws holding it in at the rear of the boat. Removethoae and just pull it out. When putting the new one in, yes definitely set it in the sun for an hour or so, it will make this alot easier. Then put one end into the rail, screw one of the 2 holder screws in and just work ur way around the boat to the other side with a rubber hammer and hit it in and screw the oter screw in.
Now if ur doing the actual rail as well, then u will have to remove about 200 screws that hold it in and u will need at least one other person to help hold the new one on the boat while u screw in a few screws (spaced out around thr boat)to
hold it in, then finish puttin all the screws in then do the rubber. Any questions let me know. Good luck!!
