Re: Has anyone had detrimental effects from soaking carbs in carb cleaner?
I just use hot water, or a mild detergent. Then you blow it out with compressed air. It's really good at breaking apart varnish and dirt. What you can use depends on the type of bath you have. I've been able to use Por-15 marine clean in one before, and that worked really well - never tried it on a carb though. 10-20 minutes usually does the trick quite nicely.
It's not as good as a chemical bath, but it sure beats disassembling 90-brazillion o-rings, plastic bushings, and little bits o' fun. I suppose there's really no reason you couldn't use a caustic solution in the sonic bath, but since caustic does just fine by itself it's really overkill.
