Re: hardwood floors in 30"Pacemaker
Diamond,<br /><br />I wouldn't recomend normal laminate composite flooring for a boat. The biggest enemy of these types of flooring is moisture. You should check in your area for a "wilsonart" flooring distributor. They have a product line called "Performance". It has a "recycled plastic" core as opposed to high density fiber board. You may have to prod them a little because this product is not known as well as the "residential" product lines. It was formulated towards commercial applications (banks,malls, etc.) As of a couple years ago, you had to be factory certified to install this product. I did the cert. class and it wasn't that much different than installing the "normal" flooring. In short, because of the "plastic core" and increased surface film layers, this flooring could be installed in a swimming pool. It should last forever on your boat. I'm trying not to get too long , if I can help more let me know.
