hard to start
BENJA
hard to start
I have a 76 115hp, I have to crank on it for ever so it will start I squirt a little fuel into the carbs then a few more cranks and then it starts, any suggestions? anything wrong?
andrewkafp
Re: hard to start
Re: hard to start
Are you talking "Cold" start ? Make sure the choke butterfiles are fully closed. These motors need a good Chokin'... :eek: <br />Follow the normal procedure.<br />Connect fuel, squeeze bulb til hard, put in neutral, raise fast idle lever about vertical, <br />Turn key to on,press and hold choke button (Do you hear a click?) turn key to start. Don't crank for too long as you can damage starter. Just short bursts til she starts.
BENJA
Re: hard to start
Re: hard to start
thanks I dont want to burn the starter and yes the choke clicks. Another question where should the bulb be? I have one but it is not connected. should it be by where the fuel line connects to the motor? sorry for the questions but Im a newbie to this but Im having fun though!!<br /><br />thanks<br />Ben
andrewkafp
Re: hard to start
Re: hard to start
Don't think it matters where you put it, between tank and motor, but mine has tank, 1ft tube, car fuel filter, 1ft rubber tube, bulb, 2ft tube connector.. motor. Works for me.
Greg New Zealand
Re: hard to start
Re: hard to start
The bulb should be on the fuel hose just before it connects to the motor. It's purpose is to pump the fuel from your tank and fill the carbs prior to starting. After start the fuel pump will draw enough fuel. The bulb must be pumped up hard before you try to start - sounds like you are not getting enough gas to start.
LubeDude
Re: hard to start
Re: hard to start
Originally posted by BENJA:<br /> I have one but it is not connected. <br />thanks<br />Ben
Ya think maybe thats why its so hard to start???<br /><br />If you do not have the bulb hooked up, the combination of the choke and the fuel pump have to fill the carbs with fuel before it can start, not a good thing. Hook a new bulb up between the tank and the engine.
BENJA
Re: hard to start
Re: hard to start
thanks for the help I'll hook up that bulb and then give her another try
andrewkafp
Re: hard to start
Re: hard to start
Didnt even see that... :eek: :eek: Lubedude.. Just took it for granted that it would be connected.<br />Well spotted.
rickdb1boat
Re: hard to start
Re: hard to start
Make SURE the arrow on the bulb points toward the engine.
kenneymc
Re: hard to start
Re: hard to start
I have the same motor and just got it a month ago. A trick i was shown was to pump up the bulb until hard, this is with the motor trimmed/tilted up. Once hard continue to squeeze it some, just until a couple of drops of gas drip from the motor. Then trim it down level into the water or on muffs (water flowing of course). Press and hold the choke while turning over the motor. Mine will cold crank like this in about 2 to 3 seconds.
BENJA
Re: hard to start
Re: hard to start
hooked that bulb up and squeezed until hard cranked twice and started right up thanks for the help!!<br /><br />Ben
