hard to start v6 200 johnson outboard 1987
rovkyman57
just got this outfit would like some pros and cons about this motor but the real question is why is it so hard to start after it has been setting for two or three days , i turn key i hear the chokes click shut then i push in key hold and engauge starter ,motor turns over and over and over till finally it will fire .im talking thirty minutes at least.but after it fires up no more problems .turn it off it fires right back up no delays at all.all inputs welcome. thanks rockyman57
dehydrated
Re: hard to start v6 200 johnson outboard 1987
sounds like a fuel delivery problem check the primmer soliniod make sure its working properly i boats parts sells a rebuild kit for this
Silvertip
You should not hear any clicks until you push in on the key -- that's what activates the choke. Starting procedure is as follows:
Squeeze primer bulb until firm. (Fills the carbs with fuel)
Raise fast idle lever or activate fast idle function. If you have a control box mounted to the side of the boat the fast idle lever is on top of the box. If all you see is a a control lever on the side of the boat, then push the button in the center of the lever and move the lever forward. Pushing that button disengages the shift linkage so you can advance the throttle without going into gear.
Now turn the key to start the push in on the key.
When the engine fires release the key and bring the idle down to an above idle warm up setting.
Be prepared to push the key in momemtarily if the engine tends to slow down and die. This is a carbureted two stroke and they need a bit more fuel during warm up.
Will Bark
Do evrything silvertip says except if you have a Morse control box then you have to pull the lever out to disengage the gears and go to fast idle. Make sure the primer bulb is firm before you try to start the engine; mine loves all that fuel.:D
rovkyman57
ya know i forgot to mention one thing dont know if it makes a difference but my motor is 1987 limited edition johnson 200, i do thank ou guys for the great info .will try this out to see if it helps me
