Re: hard to start 88 Johny 120
olm....not sure what you mean when you say "crack" the throttle, but the clicking you hear is the choke working so that is good. I think you answered your own question though, you absolutely need a primer bulb in the fuel line back towards the motor, this fills the carb bowls for cold starting. If you go and buy a primer bulb and put it inline with the arrow facing the motor, pump this until it gets hard(you will hear the fuel being pumped into the bowls), then push the key in to choke and turn to start and you should have a much easier cold start. Try leaving the throttle alone,(in neutral) and starting that way, if it starts, great, if it doesn't use the fast idle lever, but deffinetely get that primer bulb in there. Good Luck.
