bluesmoker
- Aug 8, 2011
- 6
I recently purchased a used 12' Livingston. The bottom of the inside of the hull is interesting. I will try to describe. Instead of there being two two-inch wide grooves on the inside of hull the corresponding to the bottom of the v's on the outside of the boat at some point a flat piece of fiberglass (perhaps 6"x10') was fit over the top of each one. This creates a hollow cavity that runs nearly the length of the boat (this covering ends just about 10 inches shy of the transom). I don't know if this is on all Livingstons or is something a previous owner did.
My issue is that this hollow space has two vent holes near the transom and it tends to collect water that is difficult to drain.
Thoughts?
Thanks!
Thoughts?
Thanks!
