Re: hard starting
Barchetta,
AS mentioned above, the fuel in your carb is evaporating when it sits for a while. Pumping the throttle helps very little because there is no gas for the accellerator pump to pump. Usually, after a couple of engine revolution, the fuel pump has run long enough to get some gas into the carb and you can pump it a couple more times and it should fire right up. However, if there is any trash in your antisiphon valve that prevents it from seating completely, then gravity will pull the fuel(very slowly) from your lines and pump back down into the tank. It takes your fuel pump 30-45 seconds to displace the air in the lines and get fuel into the carb, And it is very rare that someone actually cranks thier engine this long as it is bad for the starter.
Replace your AntiSiphon valve, and you can also do one more thing. I added a momentary switch that feeds 12v to the fuel pump, press for 5 seconds to fill the carb, pump the throttle, hit the starter, fires right up.
