Hard Starting Warm Engine After Stalling
mastergnl
I have a 1984 150hp Evinrude rebuilt 1998 with VRO disconnected. Starts fine cold and warm after running fast. When going under 5mph for a while, if engine stalls at low rpm. Extremely hard to re start. I have temp guages on both cyl heads. Temp around 150 when stalling. Crank is strong, but sounds like no spark. Dangerous when trolling near low water.
trumpetbucks
Re: Hard Starting Warm Engine After Stalling
How long can you troll before it stalls?
mastergnl
If I troll at 1800rpms or higher all day. If I go at 1500 for a while, sometimes while shifting or going into neutral I stall, If I do it takes a long time to start. Then I flood it and have to wait. Someone told because VRO disconnected I'm getting too much oil in cylinders at low speeds.
