I have a 50 hp mercury outboard which is 6 to 8 years old. I bought it used along with the boat 3 or 4 years ago. It runs fine and I am very satisfied with it, except that it has always been hard to start. My dealer/marina which does all my maintenance work and storage (not the same place I bought it initially) says it starts fine. I?ve discussed this with them each year and have them check it out, including plugs, but they still maintain it?s ok. I have to disagree with them, for the reason that the only time they start it is in shop conditions and not out in the real world. After being run for a while and then restarted, it starts immediately, but after standing for a half hour or so, or overnight, it is very hard to start.
After squeezing the fuel line bulb to make sure the fuel line is full, there are basically three ways to start the engine:
1. Turn the key until it starts. Forget this one!!
2. Turn the key, and after a second or two press it in to prime/choke the engine. Repeat if necessary. It sputters right off, but after much grinding it may or may not start. It acts like it has a very weak idle, but once started it idles ok.
3. The only real way to start it reliably is to advance the throttle and then use procedure 1 or 2.
There are times when it is really necessary to get the engine started in a hurry, and it just doesn?t seem that my engine is behaving normally. If it otherwise wasn?t just fine or if new ones weren?t so expensive I would trade it in. Is this the way I can expect a 50 hp Merc to operate?
