Hard Starting 1975 4HP
Papa Steve
I have a 4W75A 1975 Johnson 4HP. It has been sitting for a long time. I got it out to start it up. It took about 15 pulls. I began with new gas/ oil. I started but ran kind of rough. So I added some Sea Foam and ran it for about a hour at various speeds. It seemed to run better. I adjusted the idle low/ high and seemed to run good. But when I shut it off or if it died on me for idling it too low I hd a very hard time restarting it. i would need to choke it adjust the idle a little pull pull pull pull pull. What do you think the problem might be? Is it my points, condenser, coil??? Thanks for helping me. Papa Steve
The ignition system was designed and built to produce up to 28,000 volts.------Laying the plugs on the plug will often show spark.-----But that spark may not be from 28,000 volts.-----So does spark from your magneto jump a gap of 5/16", yes or no ?------A 1975 model 4 hp either has cracked original coils or a new set already.----Just the way it is.
oldboat1
In addition, reset the high and low speed needles to proper initial settings, then fine tune. Initial setting for the h.s. is 1 turn open for lightly closed. l.s. is 1 1/2 turns open. Final settings will probable be a bit leaner (clockwise), but motors vary. Need to be in a test barrel or the lake, properly warmed up. If you can't fine tune it and the ignition is performing like it should, clean/rebuild the carb -- and lose the Sea Foam in the tank.
