I have an'81 25 HP Johnson with a manual start & manual choke. Once I get the OB runing she runs like a top howvere it's the starting that I have problems with. What I have to do is take the cover off, soak a rag with fuel & cover the air intake on the black plastic air intake. THat's the only way to get it started. But once it starts & warms up, it's great. If it cools, I have to do the rag trick again.Some of the things I have done so far to rectify the problem, I have placed new plugs in the engine, I have taken it to 2 different shops & they both say it runs fine, I have done a carb kit, I have changed the fuel connectors on the line from the tank to the OB & I have also replaced the electonic coil with lead for each plug. Someone on the Wooden Boat forum suggested this forum however I have had some great ideas with the WB Forum. Here are some of their suggestions;1- change the whole hose from tank to OB. 2- If I haven't stabilized the fuel, there is a chance that the carb is plugged with varnish. (If so how do I check for varnish & how do I get rid of it)3- Another suggestion that the "syncronization" between the spark advance & the throttle could be the culprit. 4- Another was the choke pivot was worn out & leaking air & not enogh vacuum to pull fuel from the main jet. the only way to rectify it was change the carb.<br /><br />I guess I'm just p****d with bringing it to mechanics & getting ripped for a pretty simple OB. <br />Thanks
