gn83tm
- Sep 7, 2008
- 22
Hoping someone here can help me. I recently purchased a 1996 Bryant 212 bowrider with a 7.4 Bravo One Mercruiser. Under hard acceleration (pulling skiers up, etc), the steering wants to pull hard to port and it's about all I can do to hold the wheel straight. Once on plane I can throttle back and adjust the trim a little to make it better, but it's always kind of there. Cruising along steadily and then powering up causes the same problem. The boat always steers port easier than it steers starboard.
The boat has the DHB steering actuator and I'm wondering if that's the problem. The cable guide tube seems to move freely for the short distance it needs to when the wheel is turned both directions. According to the PO, the cable and the pump were both replaced last year. I removed the cable from the actuator and it moves freely. The outdrive also moves freely without the steering hooked up. I re-aligned the cable guide tube a little so the flats are as vertical as I can get them with the cable nut tightened down.
I realize there's going to be some pull due to the single prop drive, but this is beyond that and feels like it could be dangerous. Any ideas? Thank you.
