levittownnick
- Jul 2, 2003
- 789
Model J150EXEUE S/N G04209751
Compression #1-105, #2-102, #3-107, #4-102, #5-97, #6-107. Did the link & sync procedure. Replaced the optical pick-up because the analyzer indicated a problem. Measured spark voltage using the 7/16 gap method, (good results). Working on the "step 4-power coil test. The meter I'm using is an automotive type that has a Maximum scale instead of a Peak scale-I am thinking that they are the same (I could be wrong). Manual specifies measuring the orange then the orange/black stator leads to ground on the 500V range, results should be zero. I see about 0.6V? Next measure the orange to the orange/black wire. should be 50V. I see about 5V (not good). Ohmmeter test indicate 58 Ohms (spec 55 +/- 10 Ohms) Ok. Removed flywheel. The coils look new (they are the original). One of the magnets has a cracked corner. Is this acceptable and normal? The starter drive gear was jammed into the flywheel and the bearing that is in the cover melted the cover and shifted position about 1/16 inch. I would think that I need a new cover or should I try to drill out the cover and put in a bushing to hold the bearing? Right now I'm lost and would like advise:
1) Is the voltage reading misleading because I possibly am using the wrong type meter?
2) Do I have to replace the flywheel?
3) What would you do with the housing cover?
4) Even starting fluid would not get the engine to start or kick today.
5) Any other items that I should be doing?
Sincerely,
Nick
Sincerely,
Nick
