I've been fixing various problems on my 1965 75hp Starflite IV but now the engine won't start unless I give it half throttle. Even after it starts when I back the throttle down the engine will idle rough and then die. At half throttle or more the engine seems to run just fine. <br /><br />Before I "fixed" the last couple problems I found it would idle fine. The only changes I made were fixing a broken wire, setting the timing, and replacing a bad point.<br /><br />Any ideas on what could be causing the problem? I'm not sure what to look at next.
