jprice
- Sep 10, 2009
- 58
This is basically a continuation from this thread: http://forums.iboats.com/showthread.php?t=352865
But since the issue has become engine related, I figured I'd start over here.
It's a 1996 Speedster with the twin rotax engines. Been having issues with the overheat alarm going off after only a short time on the water. So as recommended by a local seadoo shop, I should start by flushing both engines, which I just did.
At the end of the 2-3 min flush on the right engine, the overheat alarm starts going off. I check, and neither the engine or exhaust are even remotely warm.
So I'm pretty happy thinking it's a thermostat issue. But since I'm doing it, I go ahead and flush the left anyway. No problems there.
Replace the thermostat, and flush the right again as a test.
Then I peek in the engine compartment and see this... (it's a little hard to see, but there's a small stream of water coming out of the block towards the exhaust)
Here's a view of the crack (again, a little hard to see, but it's there)
Is there any way to fix a hairline crack in the engine block other than buying a completely new engine?
I've read about some successes with JB Weld. Has anyone used it in a similar situation? If so, how well did it work?
