FreeBeeTony
- May 15, 2002
- 3,997
I started my 165 IL6 Mercruiser yesterday for the first time this season! Sounded great, can't wait to get it in the water. I installed a FWC system this winter using a H/E given to me by a friend, its from a V8. The end cap was leaking. It appeared to be loose so I tightened it. Still leaked, even got worse if I made it to tight. I would like to put a new gasket on it. Where can I find one? will a Mercruiser dealer have one? Or should I try some kind of sealer (permatex)? I put in a 160deg thermostat and the temp did not go any higher than 160. The return raw water didn't seem too hot.........maybe because its not under a load yet and the thermostat isn't opened all the way yet?
