Re: gun rebluing.
deimus, just my 2 cents worth I have many older firearms that the bluing is worn on that are used in bad weather, with todays lube it should not be a problem, the bigest problems are caused by a damp case, if the case is dried each evening and the gun lubed with a good product and kept out of the case except for transportion, never leave a gun in a case it will always rust the hard cases are the worst. You should not have rusting using this method, I have for many years with out problems and hunt with some weapons that ars 3 genrations old, as you can tell by now I don't belive in rebluing weapons in most cases. I have a couple redone that suffered fire damage but by a proffesional. If your weapons have sentimental value they deserve better than you are thinking, why destroy the looks and value of a fine old memory, you can never replace it or make it original again and with the new gun look alot of the memories are gone (my dads model 12 has a thumb print in it from him setting in a duck blind in the rain for many years, I think of him ever time I see the print and it's great memories) if nothing else think about purchasing another gun for bad weather hunting. As you can tell these are just musing of a old man---Bob
