Guest 2611A onboard battery charger
motorpoor
1st Guest 2611A lasted about 2 years. Last bought in July this year. Properly connected and charged fine. Is there a possible wiring problem with my Polar Craft or just bad luck with chargers? What is the best dual onboard charger?
Silvertip
Honorary Supreme Mariner
Re: Guest 2611A onboard battery charger
Boat wiring has nothing to do with charger wiring or charger operation. I've used guest chargers for ages and never lost one. A lightning strike or a power surge when plugged in can destroy any electronic component -- "stuff happens".
Ike-110722
I would go with Silvertip. just bad piece of equipment or some outside influence.
John_S
Guest had a problem with the earlier version of this charger, but that was causing an overcharge on a two battery set-up, not a dead charger. Contact Guest for a replacement.
