Well, I thought I had this solved by replacing a kill switch but it's reared it's ugly head again. I have a 1990 GT-150 crossfire. At times I have no spark, confirmed with spark tester. When that happens, I can unplug the big red plug, jump the solenoid and I get good spark. Then without touching anything else, I plug the red connector back in and I still have good spark. This happens randomly. When I lose spark, I go through the above procedure and it works every time. I have replaced the wiring harness from the switch to the motor. I'm starting to think the problem is a short in the motor wiring harness. Any ideas? Could the solenoid cause this if it's going bad?
