A little history. This is a 1990 Johnson GT150 crossfire Model # J150STLESB. Last year it developed a no spark on any cylinder. Tested with a 6 cylinder spark tester with the plugs out. Took it to the pros and they replaced the wiring harness, key switch and kill switch. After a couple of trips to the lake, the same symptoms appeared again. I replaced the stator, and the pack. Also took the engine wiring harness apart and inspected every connection. Sometimes (but not always) I can disconnect the red plug at the harness and jump the solenoid and get a spark. Then (this is where it gets strange) I can connect the harness back together and get spark using the key switch. It will start several times, then for no reason that I can tell, it goes back to the no spark situation. I went through the CDI troubleshooting guide and all test were within spec.1st time I tested resulted in the no voltage in the previous post. Went out and retested and now have 235 volts. May not have had a good connection with the back piercing probes the 1st time. I'm about ready to scrap this motor and look for a replacement but I've got so much time and money in it now. Anybody have any Ideas? I'm pulling what hair I have left out.
