I just recently bought my first boat. A 1999 Capri 1952 cuddy. Overall it's in great shape with a few electrical quirks. The fuel gauge stays on full when it's in the water. When I get home and flush the engine it registers the proper fuel level. As soon as I put it back in the water though it goes right back to full. All the other gauges, with the exception of the spedo (bad pitot I think) work fine. The other quirk is the all-around light. It reads 12v at the plug. I had it working at one point then it stopped. The bulb isn't blown and I can't find a short in the post. The anodes on the outdrive look ok. A little pitted maybe. The are a few spots of galvanic corrosion on the outdrive but not bad and I'm going to fix it with some quicksilver paint. I was thinking it was an in-water grounding problem but wouldn't you have a better ground in the water? Is there a way to check the grounding system? What exactly is the ground on a fiberglass boat? Any advice would be greatly appreciated.
