Ground to steel hull?
flargin
Should a generator neutral and/or battery banks negative be connected to the Steel hull of the boat?
boat1010
Re: Ground to steel hull?
Are you talking 12 VDC? I was a little confused when you were talking generator and batteries. Most boats have both wires so you can have a circuit. But just like a car, the chassis is the ground.
flargin
for both. We have 12V system and a Generator.
So the question is should we ground the boat with the 12V circuit, AC system, or both in this situation?
flargin
I found the answer to my question at this page:Common Ground
It should have all grounds combined and attached to hull.
Back to Contents
Common Ground Point (ship's ground)
* grounds from batteries, engine, switch-panel negative bus bar, bonding system, auxiliary power generator, underwater ground plate, ship's 120 Volt safety-ground, and LORAN signal ground all meet at one point
This point must be a heavy bus bar or bracket with bolted connections.
Note: When referring to 12 Volt wiring, 'ground', 'negative' and 'ground return' are all equivalent terms.
* easy to access and located as far above bilge levels as practicable
* labeled as Common Ground Point
dr01allen
there's a difference between ground and the negative terminal.
All systems should have a common ground.
Do not connect the negative terminal of batteries or generator to the hull.
Check further on the Common Ground link for wiring DC systems.
da
