Re: Grinding them gears
Does the motor rev up before it goes into gear? If so, the throttle linkage and shifter linkage needs adjusting. It should go into gear at an idle, then rev up. Also, what RPM does it idle at? If it's too fast that causes grinding also.
If it goes into gear at regular idle and grinds it may not be going in all the way with the shifter linkage. You might disconnect the shifter and put it in manually.
If it goes in all the way at idle and still grinds then that doesn't sound good. Does it run ok once it gets in gear? Or does it jump out?
Disregard, I just saw your other post. I have bought two different aftermarket lower units that have a three year warranty and have had good service so far. One is about 4 years old and one is this year. Somewhere around 800.00 bucks I think.
