Green Smoke?
JZ100
When I Start my suzuki 50 2 stroke it blows green smoke then clears up when it runs a bit. and only does it when it is cold!
mrn714
Re: Green Smoke?
Sound as though you have water in the gas, or in the oil injector. This will cause a lock up if the leak persists. Also check comperssion in the cylinders. All should be within 5 lbs of each other. If not, may have a leak to the clooing intake.
