I have a 85 mercruiser 140. I took out for first time, running at about half throttle the boat slowly slowed to an idle had to idle back in. Would only rev to about 1100 rpm. Suspect the fuel pump. Tested with fuel pump tester got no reading but was still idling but running rough. Took fuel pump off and pumped it on bench and there is a little green goo coming out of sight tube ( sight tube is green about 4 inches up ) I have the old style pump with the bowl facing up. Im assuming that means the pump is bad? What is the green stuff?
