"Great Stuff Foam"......won't come off my hands
11 footer
You all have heard of or used "Great Stuff foam" right?<br /><br />It comes on a can and its used for sealing up stuff.<br /><br />I got it on my right hand, as soon as I for it on my hand I took a rag and wiped it off. When I got into the light again I saw that where it was on my hand is black, looks like I have dirt on my hand, that was yestersday, and after washing it many times, it won't come off. <br /><br />Any suggestions?
Paul Moir
Re: "Great Stuff Foam"......won't come off my hands
Damn near nothing. Dow recomends you abraid it off. It's only slightly easier to get off then PL PREMIUM.<br /> Great Stuff FAQ <br /><br />Enjoy your exfoliation! :)
JasonJ
Yup, time is about it. I got 2 part foam on my hand and had to chew the stuff off....
LubeDude
Ya, it will come off in about a week when your hand grows new skin! :p <br /><br />Thats what they make latex gloves for, among other things! :D
11 footer
I got it off with a one of those green scrubing pads, took about five mins under warm water, but it worked :)
FLATHEAD
Next time get the power washer, that oughta do it.
Now this one made me smile :) <br />BTDT and just when you think your gonna get away without dragging out the laxtex gloves :eek: happens everytime :D
eurolarva
Is this the foam you use to insulate your home? If so it is nasty stuff. Have to wait for it to dry before cutting or working with it. When I install windows I use fiberglass instead of that stuff. I have had it expand to a point where the windows will bind.
flashback
try some acetone, tho i'm not sure if the cure is worse than the illness :D
gaugeguy
Originally posted by Flahthead:<br />Next time get the power washer, that oughta do it.
Your killing me man :D LMAO :D <br /><br />Went around with a black spot for three days till the skin died and was able to peel it off :(
ChrisMcLaughlin
So much for reading the directions. This one sounds like the ole boat plug story. Yup, I dun that too!!!! :D :D
Paul Moir
Flashback - they (Dow) actually reccomends you use acetone for the uncured stuff. :eek: <br />Once it's cured, it's like any other urethane: undissolvable.<br />I'll bet paint stripper would work though.
Ryoken
POR 15 is the worst stuff ever to get off. it will only wear off, takes about a week...<br /><br />great product, but boy they aren't kidding when they say to wear gloves ;) <br /><br /> http://www.por15.com/
daveswaves
Ensign
Heres a messy solution but it works. Take the gloves that you were supposed to wear BEFORE you used the foam, slather your better halfs really good hand cream on your hands, put the gloves on over the hand cream. Work away on your project and try and ingnore the fact that your hands feel yucky. It worked for me. :)
