Greasing the Universal on a '86 Merc 4.3L V6 205 HP Alpha One
The 86
I have successfully removed the upper and lower drive from the transom in a project to replace the impeller and grease the universal joint and getting an idea of what everything looks like.
Before greasing the universal and spline and inserting back into the transom, should I clean out the grease that is in the bellow? Should there be a grease in there from previous years of greasing?
I understand I will also be replacing the outdrive gasket and associated rings before reassembly as well. Anything else I should do or look for while working this project?
Thank you in advance for your help!
90stingray
Re: Greasing the Universal on a '86 Merc 4.3L V6 205 HP Alpha One
Wipe out all old grease. Grease gimbal bearing and turn by hand and grease and turn... until fresh squeezes out. Might want to check the alignment with an alignment tool... or take it to a shop and have them verify alignment. <---- important! Dont just skip this step.
dubs283
inspect all bellows - u-joint, shift, and exhaust
note gimbal ring play
check condition of engine coupler, check engine alignment and grease the coupler, not the shaft on the drive
check gimbal bearing and grease
inspect trim senders/wires/operation
pressure test the drive after replacing water pump assy
cr2k
Make sure everything is in FORWARD gear, shift box and drive.
Yes clean out the grease as it is not good for the rubber. Is the bellows in good shape (less then 5 years old?) you also need an alignment tool to check your alignment or drag it to a shop for them to check (no outdrive on the boat). Use a good spline grease on the yoke splines. Turn the gimbal bearing by hand. ANYTHING other then silk smooth replace it. Any rust on it Replace It. Clean out the cavity behind the shift slide. Put some grease on the end of the slide to hold the arm there during reassembly.
The 86
Thanks guys! Everything went smoothly!
