Grease leaking from midsection 87 johnson 90 hp VRO
Mhardy
I bought a used boat about a month ago and have taken it out a few times now. the last time i loaded it up on the trailer, i noticed a decent amount of marine grease on the lower part of the midsection. This has not been the case with the last couple times out on the water. I am fairly new to boat ownership, so i'm sorry about my lack of knowledge. any insight about whether or not this is a problem (and what is causing it) would be greatly appreciated!
Thanks.
jakedaawg
looks like someone got a little carried away with the grease gun is all. not a big deal.
emdsapmgr
There is an upper and lower bearing on that swivel bracket. A grease zurk is approximately in the center of the bracket. When you grease it, the grease travels up and down to keep those bearings lubbed. Agree someone got carried away. Wipe the excess of with a rag.
Mhardy
The previous owner. Glad to hear it's most likely no problem. Was just curious since there was so much and I hadn't seen any in this area on my other couple trips out.
