Motor is a 1980 Johnson 9.9 Sailmaster Long shaft.
Purchased this motor several months ago. Changed water pump. Changed lower unit lube. Motor runs fine, but there is heavy brown grease coming out or the small holes just above the cavitation plate. It seems to work its way out and then stays on the cavitation plate Motor is on a sailboat so it is not run much. Previous owner used a lot of automotive type brown grease on this motor. Is this seepage the result of over servicing, or is there a bad seal?
