grass stains
Ron G
ive cleaned and scubed on the lower half of the boat but cant get the grass stains out any recomendations?
chuckz
Re: grass stains
Stop driving the boat on the grass :)
Realgun
Re: grass stains
You can try bleach. I would suggest you stop playing OO spy games with the boat though.
Ron G
Re: grass stains
If you are going after lunker bass in the south....you need to be in the grass. So the question still is..how do you get old grass stains out of the paint?
TwoBallScrewBall
Re: grass stains
Laughing my a$$ off at the 2 replies! :D <br /><br /><br />Ron, there are various hull cleaners around that are designed for the scum line or water stains. <br /><br />What kind of boat, aluminum, glass or wood? <br /><br />Depending on how long the stains have set there, it may be pretty tough to get them out (think you figured that out already...)
Ron G
Re: grass stains
its a 93 180 bumble bee fiberglass i bought it last year spent a week tring to get the old grass stains outtryed 3m cleaners grease lighting and its in the bottom half which is white<br />thanks ron
Realgun
Re: grass stains
Could or would it be possiblee to compound out the stains? That 3m rubbing compound is pretty agressive I understand.
Desert_Bassin
Re: grass stains
I'm wondering if its actually grass stains, and not some kind of alge stain from sitting in the water for an extended period of time that has actually penetrated the finish. I know I have seen many boats that are sitting in slips with the worst looking bottoms. I just cant imagine cruising thru the grass for bass will leave grass stains that tough. I've never had lake vegetation leave a stain on my boat. Must have a better grade of grass in Tenn. than in So. Cali.
rwidman
Re: grass stains
Starbrite Hull Cleaner from the marine center will get rid of the stains without damaging the gelcoat. Dekswood deck cleaner from the home center is the same chemical (oxalic acid) and will work also. Bleach won't work, neither will rubbing compound, and rubbing compound removes the surface of the gelcoat. You will need to rewax after using the hull cleaner.
crazy charlie
Re: grass stains
Buy the cheapest liquid toilet bowl cleaner from Wally world.It will work almost as fast as the best cleaner available(on-off bottom cleaner)
mattttt25
Re: grass stains
have you tried on/off? if that doesn't take it off, i'm thinking you need to break out the compound.
Ron G
Re: grass stains
what is on off?I scrubed again most came out but the white has some brownish in it might be in the gelcoat.thanks for the info all its mostly guntersville ala. grass the best in the world.
crazy charlie
Re: grass stains
On off is an acid based fiberglass hull and bottom cleaner.It is THE best!! Very similar results from liquid toilet bown cleaner.Wear rubber gloves!! Charlie
