Re: Grabby surge brakes?
As promised, here is the update and resolution to the problem.<br /><br />The EZ loader NW division folks were kind enough to put their production of new trailers on hold for a couple of hours to troubleshoot this problem. I had no less than 6 people trying to figure out what was going on.<br /><br />Their first guess that tongue load was too high proved not be the case (600 pounds on a 7200 pound trailer). After testing everything on the trailer from bearings to brakes, they did a level check. Turned out the back was 6 inches higher than front. Now mind you, the trailer visually looked level as it is hard to see such a difference across such a long load (the boat alone is 23 feet). The thought here was that if the trailer is not level, the surge mechanism is not going to be able to travel easily which makes sense.<br /><br />While they did not think this would make a difference, they lubricated the surge mechanism and replace some kind of roller (unfortunately, I didn't see them to do this so the description here may not be 100% percise). Surprisingly, the lubrication made a huge difference. There was some jerking but I would say about 80% of the problem had gone away.<br /><br />The above did not quite last though in that by the time I drove home (only 11 miles in traffic), the brakes had already started to grab more and more. So I went ahead and special ordered the 10,000 pound ball mount that was about 2.25 inches higher than the current one. I installed the new mount yesterday and it definitely took care of the problem. There is still the last 20% grabbiness here, but the rest is gone. According to EZ Loader, the larger surge mechanism used on these trailers just doesn't work as smoothly as the smaller ones.<br /><br />I also got a bonus with the new mount. Namely, the overall handling of the car and trailer has improved tremendously. The ride was not bad before but I could easily feel the trailer in the back and steering was quite sensitive. Now the tow SUV seems to have strong command of the load in the back and the only time I notice the beast is on bumps and sudden ups and downs on the road. The brakes are also nicely proportionally instead of all or nothing. Milkeways suggestion of slow rolling takes care of most of the residual grabbiness.<br /><br />Thanks again for all the suggestions. Learned a lot here and know better than to tow something without actually measuring level.<br /><br />Amir
