GP1200R won't pass 45mph
smokintalon
GP1200R, have the D plate installed, so that rules out the cat. Plugs are good (ohm tested and checked gap with feeler gauge). Doesn't act like its skipping, so that should rule out the ignition. I do have the waveeater clips installed. Compression is 125 across the board. Ski runs good, just won't pass 45mph (does seems a little sluggish coming out of the hole compared to before the prob started). Was topping out at 68 before.
Where should I check next?
