Hey guys. I have some problems and i believe they involve my coil pack but i am not sure. My engine runs fine out of the water but then when i get it in the water, it only runs about half speed. I fixed a fuel leak around my primer and i thought that would cure my problems but it did not. My motor will start and run when the bottom spark plug wire is off. It will not run when the top spark plug wire is off. I switched sparks plugs and the same thing happened. I guess my question is can the coil go bad on just one spark plug or do i have more problems then i think i do? Thanks for your time and advice.
