This motor is fairly new to me for about 2 months now and a work in progress trying to get it going. Its a 1977 70 hp Johnson . I thought after a new switch and a broken kill wire in the harness to the engine it was doing ok. It has been running fine except its hard to to get going at first without a few minutes on high idle and warming up then its fine thru the rest of the day. Today my cousin and I were out for a day of fishing and after warming up as always pulled away from the ramp into the middle of the lake and gave it the gas. Ran fine for a couple of minutes then sounded like it was running out of gas. Checked all the fuel lines and connections and the screen on the screw off filter. All good. Started it up and ran fine on low idle and put it in gear , all good untill I gave it gas then same thing like running out of gas. This time I hit the choke and off it went for a sprint second then lost power and another hit on the choke and off it goes again for a sprint second.The primer bulb is hard as a rock, and yes a full tank. It idles fine in gear and goes a little more than a modest walk but it wont go up to a high idle without dying .
I am thinking fuel pump? Just sounds like its running out of gas on a higher throttle. In the past I have checked all spark, spark plugs and compression. All looks to be normal. Someone point me in the direction to look for another problem?
