Re: Good spark and compression, one cylinder only
Newfie.... That problem is usually caused by one of two things (or both) assuming that the points, condenser, and coil are okay.<br /><br />The first is that one of the spark plug wires has chaffed through which allows it to ground out as the armature plate turns.<br /><br />The second is that too much rocking type motion exists in the seating of the armature plate (the plate the coils etc are attached to). The solution to this problem follows.<br /><br />********************<br />(Magneto Armature Plate)<br /> <br />If the armature plate has a a loose fitting, wobbling motion (the plate that the points, coils etc are attached to), it is usually caused by a slightly worn support ring. This allows the point setting to change erratically as the armature plate turns.<br /> <br />The cure is to remove the armature plate so that the support which is attached to the powerhead with 4 screws is visible. Then, with a screwdriver and hammer, or some tool of your choosing, and looking straight down at the support ring, make an indentation at what would be called the 12, 3, 6, and 9 O'clock positions. Install the armature plate and check for a smooth turning wobble free movement.<br /><br />You may need to do that procedure a few times to obtain the proper fit (not too tight, not too loose), but it's worth the effort. <br />********************
