Re: good or bad motor
I ran a 1974 50hp merc for 6 years on my old boat.<br />those 4 cylinder motors idle great, used it to troll<br />for salmon.<br />It finally died after a zillion hours on it.<br /><br />Started pushing this "oily goo" out the exhaust ports<br />i think it got water in the cylinders, so i parted it off.<br /><br />Check the drive shaft. if they are carbon steel they will freeze up in the motor unless you have the lower unit off regularly.<br />you might be able to find a stainless shaft to replace it with.
