Hello all. I have another thread going about an overheating issue I have with my port side motor. FYI, I have twin 1988 5.7l mercs with alpha drives. I have read and been given some advise to diagnose the problem. In order to eliminate or confirm the problem is at the outdrive end (ie: impeller) I have a thought.....If I got some hose and made necessary extentions, coupling, etc -I would connect the water intake line from my port motor (at thermostat) and connect IT to my starboard thermostat housing. I would then re-route my starboard water intake line to be connected to the port motor side. My theory is that if I then ran both motors, the cooling water to each motor would be supplied by the opposite drive / impellar. If my problem is in the drive, I would then expect my starboard motor to now overheat and my port motor to run fine. If my problem continues to be the port motor then I would KNOW its not being caused by the outdrive / impeller and that it is definitely in the engine. YOU follow??? Please,.. tell me your thoughts! Will this work?..can I cause any damage?..Good or Bad idea?..(fresh water cooled boat by the way)......THANKS!
