Motor is a 60's - (still trying to figure out year). Has not run in a number of years. As part of troubleshooting a non start issue did a compression test and got 60psi in each cylinder (no real variation between the 2) after 5 hard pulls (WD 40 in cylinder). Ive read somewhere I should be getting 90 or more. Im currently debating if putting money into it. What do you think about those readings? Thanks
